跳转到主内容
TomTom One XL Screen Replacement
你所需要的
  1. TomTom One XL Screen Replacement, Back Panel: 步骤 1 中的图像 1,2 TomTom One XL Screen Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Remove the 4 .4mm screws on the back of the device.
  2. TomTom One XL Screen Replacement: 步骤 2 中的图像 1,1
    • Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
    • You can rotate TOMTOM XL to make prying back off easier.
    • Be careful not to injure the two wires connecting the pieces.
  3. TomTom One XL Screen Replacement: 步骤 3 中的图像 1,1
    • After prying both halves apart, they will be connected by two wires.
    • Carefully set the two halves next to each other making sure not to stress or damage the wires.
  4. TomTom One XL Screen Replacement: 步骤 4 中的图像 1,2 TomTom One XL Screen Replacement: 步骤 4 中的图像 2,2
    • Using the tweezers separate the wires connecting the battery and speaker to the mother board.
    • Be gentle while pulling the wires out, the plugs are easily injured.
  5. TomTom One XL Screen Replacement, Screen: 步骤 5 中的图像 1,2 TomTom One XL Screen Replacement, Screen: 步骤 5 中的图像 2,2
    • Locate the 4 .4mm screws connecting the circuit board to the front panel.
    • Use the T6 Torx screwdriver and remove the four screws.
  6. TomTom One XL Screen Replacement: 步骤 6 中的图像 1,3 TomTom One XL Screen Replacement: 步骤 6 中的图像 2,3 TomTom One XL Screen Replacement: 步骤 6 中的图像 3,3
    • Locate the ribbon cable connecting the front panel to the circuit board.
    • Locate the white tab locking the ribbon in place.
    • Using precision tweezers push the left and right side of the tab forward.
    • Gently pull the ribbon to disconnect the circuit board from the front panel.
    • If gently pulling on the ribbon doesn't release it then the tab hasn't been pushed far enough forward.
  7. TomTom One XL Screen Replacement: 步骤 7 中的图像 1,3 TomTom One XL Screen Replacement: 步骤 7 中的图像 2,3 TomTom One XL Screen Replacement: 步骤 7 中的图像 3,3
    • Use the palate knife to pry the screen away from the front panel.
    • Pry between the light gray board and the black boarder of the TOMTOM XL screen.
    • Use moderate pressure when prying, slide the palate knife back and forth, and eventually the screen should pop out.
结论
DeVhan
于03/11/15注册
401 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 899
