跳转到主内容
TomTom One XL Charging Port Replacement
你所需要的
  1. TomTom One XL Charging Port Replacement, Back Panel: 步骤 1 中的图像 1,2 TomTom One XL Charging Port Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Remove the 4 .4mm screws on the back of the device.
  2. TomTom One XL Charging Port Replacement: 步骤 2 中的图像 1,1
    • Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
    • You can rotate TOMTOM XL to make prying back off easier.
    • Be careful not to injure the two wires connecting the pieces.
  3. TomTom One XL Charging Port Replacement: 步骤 3 中的图像 1,1
    • After prying both halves apart, they will be connected by two wires.
    • Carefully set the two halves next to each other making sure not to stress or damage the wires.
  4. TomTom One XL Charging Port Replacement: 步骤 4 中的图像 1,2 TomTom One XL Charging Port Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using the tweezers separate the wires connecting the battery and speaker to the mother board.
    • Be gentle while pulling the wires out, the plugs are easily injured.
  5. TomTom One XL Charging Port Replacement, Charging Port: 步骤 5 中的图像 1,2 TomTom One XL Charging Port Replacement, Charging Port: 步骤 5 中的图像 2,2
    • If this is your first time solder then refer to IFixIt's safety guide.
    • Locate where the charger port goes on the circuit board.
    • Locate the four connecter on circuit board and charger port which need to be soldered.
    • Don't forget, the soldering iron is hot.
  6. TomTom One XL Charging Port Replacement: 步骤 6 中的图像 1,3 TomTom One XL Charging Port Replacement: 步骤 6 中的图像 2,3 TomTom One XL Charging Port Replacement: 步骤 6 中的图像 3,3
    • Using your plastic opening tool press down firmly on the top of the charger port.
    • While the soldering iron is hot press it again the four corners of the charger port.
    • Don't touch the charger port with your hands, it may have heated up during soldering.
  7. TomTom One XL Charging Port Replacement: 步骤 7 中的图像 1,3 TomTom One XL Charging Port Replacement: 步骤 7 中的图像 2,3 TomTom One XL Charging Port Replacement: 步骤 7 中的图像 3,3
    • Let the circuit board and charger port cool down for a few minutes.
    • Lift circuit board up, after making sure its cool, to see if four corners are all connected.
    • Plug in the charger to make sure it works, if not repeat steps and make sure the port is making a clean connection.
结论
DeVhan
于03/11/15注册
401 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 2,411
