跳转到主内容
TomTom One XL Battery Replacement
你所需要的
  1. TomTom One XL Battery Replacement, Back Panel: 步骤 1 中的图像 1,2 TomTom One XL Battery Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Remove the 4 .4mm screws on the back of the device.
  2. TomTom One XL Battery Replacement: 步骤 2 中的图像 1,1
    • Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
    • You can rotate TOMTOM XL to make prying back off easier.
    • Be careful not to injure the two wires connecting the pieces.
  3. TomTom One XL Battery Replacement: 步骤 3 中的图像 1,1
    • After prying both halves apart, they will be connected by two wires.
    • Carefully set the two halves next to each other making sure not to stress or damage the wires.
  4. TomTom One XL Battery Replacement: 步骤 4 中的图像 1,2 TomTom One XL Battery Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using the tweezers separate the wires connecting the battery and speaker to the mother board.
    • Be gentle while pulling the wires out, the plugs are easily injured.
  5. TomTom One XL Battery Replacement, Battery: 步骤 5 中的图像 1,1
    • Using metal palate knife pry the battery from the back panel.
  6. TomTom One XL Battery Replacement: 步骤 6 中的图像 1,3 TomTom One XL Battery Replacement: 步骤 6 中的图像 2,3 TomTom One XL Battery Replacement: 步骤 6 中的图像 3,3
    • Place the backside of the battery on the sticky side of the double sided tape.
    • Using the tech knife, trim the extra tape to the size of the battery.
    • The tech knife is sharp, be careful when cutting the tape.
  7. TomTom One XL Battery Replacement: 步骤 7 中的图像 1,3 TomTom One XL Battery Replacement: 步骤 7 中的图像 2,3 TomTom One XL Battery Replacement: 步骤 7 中的图像 3,3
    • Remove the back of the double sided tap.
    • Place the new battery back inside the back panel of TOMTOM XL.
    • Make sure the wire from the battery is going in the correct direction.
  8. TomTom One XL Battery Replacement: 步骤 8 中的图像 1,3 TomTom One XL Battery Replacement: 步骤 8 中的图像 2,3 TomTom One XL Battery Replacement: 步骤 8 中的图像 3,3
    • Reconnect the battery ribbon cable to its port.
结论
DeVhan
于03/11/15注册
401 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 1,463
