跳转到主内容
加入维修社区 - 创建账户
TomTom ONE Screen Replacement
你所需要的
  1. TomTom ONE Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
  2. TomTom ONE Screen Replacement: 步骤 2 中的图像 1,2 TomTom ONE Screen Replacement: 步骤 2 中的图像 2,2
    • Using the spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
  3. TomTom ONE Screen Replacement: 步骤 3 中的图像 1,1
    • Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device.
  4. TomTom ONE Screen Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    • Once the two covers are separated, use the tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover. You may have to wiggle the wires a little bit to get them to disconnect.
  5. TomTom ONE Screen Replacement: 步骤 5 中的图像 1,1
    • Next, you must remove the motherboard from the front screen.
    • Use a Torx T-7 screwdriver to unscrew the two screws.
  6. TomTom ONE Screen Replacement: 步骤 6 中的图像 1,2 TomTom ONE Screen Replacement: 步骤 6 中的图像 2,2
    • Before you can seperate the motherboard from the front cover, you must disconnect the wire connecting the two.
    • To do so, you must use the back end of the spudger to push out the two white tabs connected to the wire, that holds the motherboard and front cover together.
  7. TomTom ONE Screen Replacement: 步骤 7 中的图像 1,1
    • Once separated, use the spudger to pry around the edges of the outer casing.
  8. TomTom ONE Screen Replacement: 步骤 8 中的图像 1,2 TomTom ONE Screen Replacement: 步骤 8 中的图像 2,2
    • Apply pressure with thumbs to remove screen from inner casing.
    • The screen and front cover are now disconnected.
终点
2等其他人完成本指南。
Alex Cauvy
于04/18/10注册
41 声望
撰写一个指南
团队
Cal Poly, Team 7-7, Maness Spring 2010 Cal Poly, Team 7-7, Maness Spring 2010 的会员
CPSU-MANESS-S10S7G7
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 9,990
