跳转到主内容
TomTom ONE Motherboard Replacement
你所需要的
  1. TomTom ONE Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
  2. TomTom ONE Motherboard Replacement: 步骤 2 中的图像 1,2 TomTom ONE Motherboard Replacement: 步骤 2 中的图像 2,2
    • Using the spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
  3. TomTom ONE Motherboard Replacement: 步骤 3 中的图像 1,1
    • Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device.
  4. TomTom ONE Motherboard Replacement: 步骤 4 中的图像 1,1
    • Once the two covers are separated, use tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover.
  5. TomTom ONE Motherboard Replacement: 步骤 5 中的图像 1,1
    • Next, you must remove the motherboard from the front screen.
    • Use a Torx T-7 screwdriver to unscrew the two screws.
  6. TomTom ONE Motherboard Replacement: 步骤 6 中的图像 1,2 TomTom ONE Motherboard Replacement: 步骤 6 中的图像 2,2
    • Before you can seperate the motherboard from the front cover, you must disconnect the wire connecting the two.
    • To do so, you must use the back end of the spudger to push out the two white tabs connected to the wire, that holds the motherboard and front cover together.
  7. TomTom ONE Motherboard Replacement: 步骤 7 中的图像 1,1
    • The motherboard is now disconnected from the front assembly
结论
4等其他人完成本指南。
Becca
于04/16/10注册
211 声望
创作了2篇指南
团队
Cal Poly, Team 7-7, Maness Spring 2010 Cal Poly, Team 7-7, Maness Spring 2010 的会员
CPSU-MANESS-S10S7G7
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 10,039
