当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
Using a spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device.
Once the two covers are separated, use tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover. You may have to wiggle the wires a little bit to get them to disconnect.
As you can see, the battery and the speaker are still attached to the device and must be removed.
Using the spudger, carefully pry out both the battery and the speaker.
When taking out the speaker, the entire plastic shock mounting casing will come out.
The battery may seem tough to get out due to the adhesive used to secure it. Just slowly work at it and do not force anything.
Once the battery and the speaker are removed, you now only have the back cover!
取消:我没有完成这个指南。
2等其他人完成本指南。
与4其他贡献者
于04/18/10注册
145 声望
创作了3篇指南
徽章: 11
+ 8更多徽章
CPSU-MANESS-S10S7G7
4 名成员
创作了6篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 7
总计 6,925
