跳转到主内容
加入维修社区 - 创建账户
TomTom ONE Back Cover Replacement
你所需要的
  1. TomTom ONE Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
  2. TomTom ONE Back Cover Replacement: 步骤 2 中的图像 1,2 TomTom ONE Back Cover Replacement: 步骤 2 中的图像 2,2
    • Using a spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
  3. TomTom ONE Back Cover Replacement: 步骤 3 中的图像 1,1
    • Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device.
  4. TomTom ONE Back Cover Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    • Once the two covers are separated, use tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover. You may have to wiggle the wires a little bit to get them to disconnect.
  5. TomTom ONE Back Cover Replacement: 步骤 5 中的图像 1,1
    • As you can see, the battery and the speaker are still attached to the device and must be removed.
    • Using the spudger, carefully pry out both the battery and the speaker.
    • When taking out the speaker, the entire plastic shock mounting casing will come out.
    • The battery may seem tough to get out due to the adhesive used to secure it. Just slowly work at it and do not force anything.
  6. TomTom ONE Back Cover Replacement: 步骤 6 中的图像 1,1
    • Once the battery and the speaker are removed, you now only have the back cover!
结论
2等其他人完成本指南。
Trevor Foster
于04/18/10注册
148 声望
创作了3篇指南
团队
Cal Poly, Team 7-7, Maness Spring 2010 Cal Poly, Team 7-7, Maness Spring 2010 的会员
CPSU-MANESS-S10S7G7
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 7,163
