跳转到主内容
TomTom Go 60 S Motherboard Replacement
你所需要的
  1. TomTom Go 60 S Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Use the iFixit opening tool to pry open the TomTom Go 60 S. Start from a corner and drag the tool around the device.
  2. TomTom Go 60 S Motherboard Replacement: 步骤 2 中的图像 1,1
    • Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device
  3. TomTom Go 60 S Motherboard Replacement: 步骤 3 中的图像 1,1
    • Once the two covers are separated, use your fingers, to gently disconnect the wires that are connected to the motherboard from the back cover.
  4. TomTom Go 60 S Motherboard Replacement: 步骤 4 中的图像 1,1
    • Next, you must remove the motherboard from the front screen.
    • Use a Phillips #000 screwdriver to unscrew the screws.
  5. TomTom Go 60 S Motherboard Replacement: 步骤 5 中的图像 1,2 TomTom Go 60 S Motherboard Replacement: 步骤 5 中的图像 2,2
    • Separate the motherboard from the front cover, you must disconnect the wires connecting the two.
  6. TomTom Go 60 S Motherboard Replacement: 步骤 6 中的图像 1,1
    • The motherboard is now disconnected from the front assembly
结论
团队
USF Tampa, Team 1-6, Nance Fall 2016 USF Tampa, Team 1-6, Nance Fall 2016 的会员
USFT-NANCE-F16S1G6
4 名成员
创作了5篇指南
一条评论
What is the purpose of single yellow wire ?
is it ok if it is disconnected ? I fear to have unsoldered it or is it just an alone wire ?
Thanks
ugo ceruti - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 18
总计 1,263
