跳转到主内容
TomTom GO Live 1535M Speaker Replacement
你所需要的
  1. TomTom GO Live 1535M Speaker Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Slip a small opening tool underneath the screen, gently sliding it around the outside edge.
    • It may be easier to start at the corners.
  2. TomTom GO Live 1535M Speaker Replacement: 步骤 2 中的图像 1,2 TomTom GO Live 1535M Speaker Replacement: 步骤 2 中的图像 2,2
    • Carefully remove the reset button cable (located on the left) and the ribbon cable.
    • Remove the screen and set it aside.
  3. TomTom GO Live 1535M Speaker Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Remove the logic board cables.
    • We highly advice that a pair of tweezers are used for this step to ensure no part is damaged.
  4. TomTom GO Live 1535M Speaker Replacement: 步骤 4 中的图像 1,1
    • Remove the 3.6mm screws with a Phillips Screwdriver.
    • After removing the screws simply lift the logic board from the base.
  5. TomTom GO Live 1535M Speaker Replacement, Speaker: 步骤 5 中的图像 1,1
    • Simply lift the speaker up and out of the base to replace it.
结论
Mathias Sagide
于01/20/15注册
618 声望
创作了5篇指南
团队
USF Tampa, Team 19-4, Blackwell Spring 2014 USF Tampa, Team 19-4, Blackwell Spring 2014 的会员
USFT-BLACKWELL-S14S19G4
1 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 263
