跳转到主内容
TomTom GO Live 1535M Screen Replacement
你所需要的
  1. TomTom GO Live 1535M Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Slip a small opening tool underneath the screen, gently sliding it around the outside edge.
    • To do this, it may be easier to start at the corners.
  2. TomTom GO Live 1535M Screen Replacement, Cables: 步骤 2 中的图像 1,2 TomTom GO Live 1535M Screen Replacement, Cables: 步骤 2 中的图像 2,2
    • Carefully remove the reset button cable (located on the left) and the ribbon cable.
  3. TomTom GO Live 1535M Screen Replacement, Removing the Screen: 步骤 3 中的图像 1,3 TomTom GO Live 1535M Screen Replacement, Removing the Screen: 步骤 3 中的图像 2,3 TomTom GO Live 1535M Screen Replacement, Removing the Screen: 步骤 3 中的图像 3,3
    • The screen is simply removed by pushing it up-and-out of the outside rim (denoted by the box).
    • As you remove the screen, you may hear a 'tearing' sound. Do not panic, as this is just the leftover substance that holds the screen in place. It will re-stick when the screen in placed back.
    • If you need to find a replacement screen, please click the link here. Link text
结论
2等其他人完成本指南。
Mathias Sagide
于01/20/15注册
618 声望
创作了5篇指南
团队
USF Tampa, Team 19-4, Blackwell Spring 2014 USF Tampa, Team 19-4, Blackwell Spring 2014 的会员
USFT-BLACKWELL-S14S19G4
1 名成员
创作了5篇指南
一条评论
I just replaced the screen. But with the cable ribbon installed the screen does not activate. The startup tom-tom sound does play. The screen is blank. But the old screen does not work as well. Prior to this the screen did work but was un responsive. Any thoughts?
Steven Kawchak - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 8
总计 857
