跳转到主内容
TomTom GO 500 Speaker Replacement
你所需要的
  1. TomTom GO 500 Speaker Replacement, TomTom GO 500 Opening the Device: 步骤 1 中的图像 1,1
    • Unscrew the two 3mm screws at the base of the device using the Torx T5 screwdriver.
  2. TomTom GO 500 Speaker Replacement: 步骤 2 中的图像 1,2 TomTom GO 500 Speaker Replacement: 步骤 2 中的图像 2,2
    • Using the plastic opening tools, insert one opening tool into the gap between the screen casing and the motherboard casing. Then insert the other tool into one of the adjacent sides and slide it around the top.
    • There are 14 latches that need to be undone.
    • The latches break easily during the opening process so we recommend purchasing a new screen casing if they break.
  3. TomTom GO 500 Speaker Replacement: 步骤 3 中的图像 1,1
    • With the screen casing unlatched, locate the right side where the two connectors are.
  4. TomTom GO 500 Speaker Replacement: 步骤 4 中的图像 1,3 TomTom GO 500 Speaker Replacement: 步骤 4 中的图像 2,3 TomTom GO 500 Speaker Replacement: 步骤 4 中的图像 3,3
    • Unlatch the connectors using the plastic opening tool.
    • The orange rectangular connector may have come off in the process of removing the screen casing.
  5. TomTom GO 500 Speaker Replacement: 步骤 5 中的图像 1,2 TomTom GO 500 Speaker Replacement: 步骤 5 中的图像 2,2
    • Separate the screen casing from the motherboard casing.
  6. TomTom GO 500 Speaker Replacement, Motherboard: 步骤 6 中的图像 1,1
    • Unscrew the five 4mm screws using the Phillips #0 screwdriver.
  7. TomTom GO 500 Speaker Replacement: 步骤 7 中的图像 1,2 TomTom GO 500 Speaker Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Unplug the connector shown near the center of the motherboard using the tweezers.
  8. TomTom GO 500 Speaker Replacement: 步骤 8 中的图像 1,2 TomTom GO 500 Speaker Replacement: 步骤 8 中的图像 2,2
    • Unplug the second connector using the plastic opening tool.
  9. TomTom GO 500 Speaker Replacement: 步骤 9 中的图像 1,2 TomTom GO 500 Speaker Replacement: 步骤 9 中的图像 2,2
    • Remove the motherboard from the casing.
  10. TomTom GO 500 Speaker Replacement, Speaker: 步骤 10 中的图像 1,1
    • The speaker is located next to the battery.
  11. TomTom GO 500 Speaker Replacement: 步骤 11 中的图像 1,3 TomTom GO 500 Speaker Replacement: 步骤 11 中的图像 2,3 TomTom GO 500 Speaker Replacement: 步骤 11 中的图像 3,3
    • Pinch the speaker at the rubber grommets and tug gently.
  12. TomTom GO 500 Speaker Replacement: 步骤 12 中的图像 1,3 TomTom GO 500 Speaker Replacement: 步骤 12 中的图像 2,3 TomTom GO 500 Speaker Replacement: 步骤 12 中的图像 3,3
    • Insert the new speaker in the rubber grommet. Use the plastic opening tool to wrap the grommet over the speaker.
结论
Nicholas Maharaj
于09/22/16注册
101 声望
撰写一个指南
团队
UC Davis, Team 2-5, Oliver Fall 2016 UC Davis, Team 2-5, Oliver Fall 2016 的会员
UCD-OLIVER-F16S2G5
5 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 455
