跳转到主内容
TomTom GO 500 Battery Replacement
你所需要的
  1. TomTom GO 500 Battery Replacement, TomTom GO 500 Opening the Device: 步骤 1 中的图像 1,1
    • Unscrew the two 3mm screws at the base of the device using the Torx T5 screwdriver.
  2. TomTom GO 500 Battery Replacement: 步骤 2 中的图像 1,2 TomTom GO 500 Battery Replacement: 步骤 2 中的图像 2,2
    • Using the plastic opening tools, insert one opening tool into the gap between the screen casing and the motherboard casing. Then insert the other tool into one of the adjacent sides and slide it around the top.
    • There are 14 latches that need to be undone.
    • The latches break easily during the opening process so we recommend purchasing a new screen casing if they break.
  3. TomTom GO 500 Battery Replacement: 步骤 3 中的图像 1,1
    • With the screen casing unlatched, locate the right side where the two connectors are.
  4. TomTom GO 500 Battery Replacement: 步骤 4 中的图像 1,3 TomTom GO 500 Battery Replacement: 步骤 4 中的图像 2,3 TomTom GO 500 Battery Replacement: 步骤 4 中的图像 3,3
    • Unlatch the connectors using the plastic opening tool.
    • The orange rectangular connector may have come off in the process of removing the screen casing.
  5. TomTom GO 500 Battery Replacement: 步骤 5 中的图像 1,2 TomTom GO 500 Battery Replacement: 步骤 5 中的图像 2,2
    • Separate the screen casing from the motherboard casing.
  6. TomTom GO 500 Battery Replacement, Motherboard: 步骤 6 中的图像 1,1
    • Unscrew the five 4mm screws using the Phillips #0 screwdriver.
  7. TomTom GO 500 Battery Replacement: 步骤 7 中的图像 1,2 TomTom GO 500 Battery Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Unplug the connector shown near the center of the motherboard using the tweezers.
  8. TomTom GO 500 Battery Replacement: 步骤 8 中的图像 1,2 TomTom GO 500 Battery Replacement: 步骤 8 中的图像 2,2
    • Unplug the second connector using the plastic opening tool.
  9. TomTom GO 500 Battery Replacement: 步骤 9 中的图像 1,2 TomTom GO 500 Battery Replacement: 步骤 9 中的图像 2,2
    • Remove the motherboard from the casing.
  10. TomTom GO 500 Battery Replacement, Battery: 步骤 10 中的图像 1,1
    • After opening the device and removing the motherboard, you will see the battery attached to the frame.
  11. TomTom GO 500 Battery Replacement: 步骤 11 中的图像 1,2 TomTom GO 500 Battery Replacement: 步骤 11 中的图像 2,2
    • Use the plastic opening tools on both sides of the battery to carefully pry it off of the frame.
    • The battery attaches to the frame with double-sided tape so this should be fairly easy to remove.
    • In this image, a smaller plastic tool was used on the left side while a larger one was used on the right side.
结论
18等其他人完成本指南。
Oriana Hone
于09/22/16注册
321 声望
撰写一个指南
团队
UC Davis, Team 2-5, Oliver Fall 2016 UC Davis, Team 2-5, Oliver Fall 2016 的会员
UCD-OLIVER-F16S2G5
5 名成员
创作了9篇指南
5条评论
Very effective guide, easy to follow and good images too, thank you Mike
Mike Jones - 回复
Most difficult part was opening the case, seemed to work best with the opening tool ends pointed down (screen up), levered the latches best.
Reassembling, the larger of the two connections that attach the screen to the motherboard case was fiddly to line up, it requires a bit of care and patience.
Thanks for these instructions.
Alan - 回复
Danke, Oriana Hone (und 3 anderen Mitwirkenden), gute Anleitung.
Und ja, wie vorgewarnt, 4 der Plastik-Verriegelungen brachen leicht während des Öffnungsvorgangs. Jetzt muss ich wohl ein neues Bildschirmgehäuse finden... Oder genügen die verbleibenden 10?
vjrott - 回复
Thanks, Oriana Hone (and 3 other contributors), good guide. Used it for GO 5000.
And yes, as forewarned, 4 of the plastic latches broke easily during the opening process. Now I guess I'll have to find a new screen casing... Or will the remaining suffice?
vjrott - 回复
tip top - alles bestens erklärt. Geduld haben, vorsichtig sein,
Ich hatte den neuen Akku zusammen mit einem Set Spezialwerkzeug online bestellt; damit ging es wirklich super.
Ron Tyler - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 43
过去 30 天: 222
总计 12,132
