跳转到主内容
Toloco EM26 Large Motherboard Replacement
你所需要的
  1. Toloco EM26 Large Motherboard Replacement, Large Motherboard: 步骤 1 中的图像 1,2 Toloco EM26 Large Motherboard Replacement, Large Motherboard: 步骤 1 中的图像 2,2
    • Remove rubber pieces at the bottom of the massage gun’s barrel with the spudger by inserting it between the rubber and the plastic, and use the tip of the spudger to pry the rubber out.
  2. Toloco EM26 Large Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the two 13.48 mm screws on the bottom of the massage gun with a Phillips #00 screwdriver.
  3. Toloco EM26 Large Motherboard Replacement: 步骤 3 中的图像 1,2 Toloco EM26 Large Motherboard Replacement: 步骤 3 中的图像 2,2
    • Remove the 8.11 mm small black screw on the edge of circular plate with a Phillips #00 Screwdriver.
  4. Toloco EM26 Large Motherboard Replacement: 步骤 4 中的图像 1,1
    • Take off the cap of the massage gun by simply lifting it off the device.
    • Be careful to secure the cap as the back part of the gun may fall.
  5. Toloco EM26 Large Motherboard Replacement: 步骤 5 中的图像 1,1
    • Pull out back touch plate to access the large motherboard.
  6. Toloco EM26 Large Motherboard Replacement: 步骤 6 中的图像 1,2 Toloco EM26 Large Motherboard Replacement: 步骤 6 中的图像 2,2
    • Unplug the three cables on large motherboard.
    • The largest cable has a tiny lever which has to be pressed down first to remove.
  7. Toloco EM26 Large Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove the three 7.66 mm silver screws on the large motherboard with the Phillips #00 screwdriver.
  8. Toloco EM26 Large Motherboard Replacement: 步骤 8 中的图像 1,1
    • Remove large motherboard for replacement.
结论
另外一个人完成了本指南。
1指南评论
Greetings!
Any idea where to get replacement parts for the Toloco EM26 massage gun?
Thanks,
Kev
Kevixfix - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 49
过去 30 天: 142
总计 1,110
