跳转到主内容
修复你的物品
维修的权力
商店
简介
Is your toilet seat getting old or broken? Use this guide to learn how to replace your old toilet seat with a new one.
配件
  1. Measure the size of your toilet bowl to know what size seat to purchase.
    • Measure the size of your toilet bowl to know what size seat to purchase.
  2. Twist the tops of the hinges of the currently installed toilet seat and pull toilet seat off to expose the screws. Twist the tops of the hinges of the currently installed toilet seat and pull toilet seat off to expose the screws.
    • Twist the tops of the hinges of the currently installed toilet seat and pull toilet seat off to expose the screws.
  3. 打开所有标签
    Mac的RAM升级套装
    购买套装
    所有选项卡都有足够的 RAM
    购买套装
  4. Unscrew the screws to detach the seat. If the screw is not loosening but is spinning as if it were, then hold the back plastic nut so that it can unscrew from the nut. Clean the newly exposed area. This opportunity will not present itself again anytime soon so take advantage of it.
    • Unscrew the screws to detach the seat.
    • If the screw is not loosening but is spinning as if it were, then hold the back plastic nut so that it can unscrew from the nut.
    • Clean the newly exposed area. This opportunity will not present itself again anytime soon so take advantage of it.
  5. Insert new special 20mm screws that are provided with the purchase of the toilet seat in the holes and tighten them. Insert new special 20mm screws that are provided with the purchase of the toilet seat in the holes and tighten them.
    • Insert new special 20mm screws that are provided with the purchase of the toilet seat in the holes and tighten them.
  6. Then re install the toilet seat by fitting the heads of the screws in the holes on the hinges of the seat.
    • Then re install the toilet seat by fitting the heads of the screws in the holes on the hinges of the seat.
  7. Close caps by twisting them in the opposite direction that you did to take off the seat.
    • Close caps by twisting them in the opposite direction that you did to take off the seat.
结论
To re-install your previous seat, follow these instructions in reverse order.
2等其他人完成本指南。
Christopher Carter
于2015年02月24日注册
231 信誉积分
撰写一个指南
团队
Cal Poly, Team 24-5, Green Winter 2015 Cal Poly, Team 24-5, Green Winter 2015 的会员
CPSU-GREEN-W15S24G5
3 名成员
创作了4篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 4
过去的30天: 8
总计 1,039
