跳转到主内容
修复你的物品
维修的权力
商店
简介
Is your toilet seat always running, even when nobody has flushed it for hours? Or is your toilet incapable of flushing completely? When calcium deposits have built up on the valve seat, the toilet continues running and cannot be flushed. This guide will help you remove those calcium deposits.
工具
配件
没有特定配件。
  1. Remove the lid from the toilet tank.
    • Remove the lid from the toilet tank.
  2. Flush the toilet, and hold down the flush lever until the tank is completely empty.
    • Flush the toilet, and hold down the flush lever until the tank is completely empty.
  3. Gently lift the float up, ending the flow of water. This will prevent the toilet tank from refilling.
    • Gently lift the float up, ending the flow of water. This will prevent the toilet tank from refilling.
  4. 打开所有标签
    Mac的RAM升级套装
    购买套装
    所有选项卡都有足够的 RAM
    购买套装
  5. Pull up the valve seat. If possible, keep it raised without releasing the float. If you do not have assistance, you may need to hold these in place with one hand. This will keep your other hand free for the next step. If you do not have assistance, you may need to hold these in place with one hand. This will keep your other hand free for the next step.
    • Pull up the valve seat. If possible, keep it raised without releasing the float.
    • If you do not have assistance, you may need to hold these in place with one hand. This will keep your other hand free for the next step.
  6. Wipe the valve seat with a rag or towel to remove the calcium deposits. Don't forget to wipe the bottom of the valve seat, as deposits can form there as well. Wipe the valve seat with a rag or towel to remove the calcium deposits. Don't forget to wipe the bottom of the valve seat, as deposits can form there as well.
    • Wipe the valve seat with a rag or towel to remove the calcium deposits. Don't forget to wipe the bottom of the valve seat, as deposits can form there as well.
  7. Release the float and the valve seat, and allow them to fall back into place. The flow of water will resume. Release the float and the valve seat, and allow them to fall back into place. The flow of water will resume.
    • Release the float and the valve seat, and allow them to fall back into place. The flow of water will resume.
  8. Place the lid back on the tank.
    • Place the lid back on the tank.
终点
Roman Snow
于2020年05月05日注册
145 信誉积分
撰写一个指南
团队
UW Tacoma, Team S1-G37, Cardinal Spring 2020 UW Tacoma, Team S1-G37, Cardinal Spring 2020 的会员
UWT-CARDINAL-S20S1G37
1 名成员
创作了1篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 5
过去的30天: 11
总计 63
