跳转到主内容
修复你的物品
维修的权力
商店
简介
Improperly tightened handles are a common cause of flushing problems with toilets.
If your toilet is not flushing completely, check to see if you have a loose toilet handle. Loose handles can be tightened easily with an adjustable wrench.
If your toilet is running continuously, make sure your toilet handle isn't too tight. When the nut on a toilet handle is too tight, the handle arm won’t fall to its resting position after flushing. Make sure the handle has enough room to allow the arm to move freely. Tight handles can be loosened with an adjustable wrench.
Broken toilet handles will prevent a toilet from running at all and require replacement. Use this guide to replace the flush lever and tank lever on a traditional gravity flush toilet.
工具
配件
没有特定配件。
  1. Lift the tank lid up and away from the toilet tank. Lift the tank lid up and away from the toilet tank. Lift the tank lid up and away from the toilet tank.
    • Lift the tank lid up and away from the toilet tank.
  2. Squeeze open the spring clasp that connects the pull chain to the tank lever. Disconnect the spring clasp from the tank lever. Disconnect the spring clasp from the tank lever.
    • Squeeze open the spring clasp that connects the pull chain to the tank lever.
    • Disconnect the spring clasp from the tank lever.
  3. Using an adjustable wrench, turn the locknut on the toilet handle clockwise until it loosens. Using an adjustable wrench, turn the locknut on the toilet handle clockwise until it loosens. Using an adjustable wrench, turn the locknut on the toilet handle clockwise until it loosens.
    • Using an adjustable wrench, turn the locknut on the toilet handle clockwise until it loosens.
  4. Turn the locknut clockwise until it releases from the threaded shank on the flush lever.
    • Turn the locknut clockwise until it releases from the threaded shank on the flush lever.
    • Remove the locknut from the tank lever.
  5. Pull the toilet handle and tank lever forward and out of the toilet tank. Pull the toilet handle and tank lever forward and out of the toilet tank.
    • Pull the toilet handle and tank lever forward and out of the toilet tank.
结论
2等其他人完成本指南。
Kristen Gismondi
于2014年11月12日注册
44,440 信誉积分
创作了95篇指南
团队
iFixit iFixit 的会员
Community
133 名成员
创作了14,532篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 6
过去的30天: 46
总计 3,218
