跳转到主内容
加入维修社区 - 创建账户
Toilet Flapper Replacement
  1. Toilet Flapper Replacement, Tank Lid: 步骤 1 中的图像 1,3 Toilet Flapper Replacement, Tank Lid: 步骤 1 中的图像 2,3 Toilet Flapper Replacement, Tank Lid: 步骤 1 中的图像 3,3
    • Lift the tank lid up and away from the toilet tank.
  2. Toilet Flapper Replacement, Shutting off the Water Supply to a Toilet: 步骤 2 中的图像 1,2 Toilet Flapper Replacement, Shutting off the Water Supply to a Toilet: 步骤 2 中的图像 2,2
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
  3. Toilet Flapper Replacement, Draining a Toilet Tank: 步骤 3 中的图像 1,2 Toilet Flapper Replacement, Draining a Toilet Tank: 步骤 3 中的图像 2,2
    • Push down the flush lever.
    • Hold the lever down until water stops draining from the tank.
    • A small amount of water will remain in the bottom of the tank.
    • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
  4. Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: 步骤 4 中的图像 1,3 Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: 步骤 4 中的图像 2,3 Toilet Flapper Replacement, Disassembling Toilet Pull Chain Spring Clasp: 步骤 4 中的图像 3,3
    • Squeeze open the spring clasp that connects the pull chain to the tank lever.
    • Disconnect the spring clasp from the tank lever.
  5. Toilet Flapper Replacement, Flapper: 步骤 5 中的图像 1,3 Toilet Flapper Replacement, Flapper: 步骤 5 中的图像 2,3 Toilet Flapper Replacement, Flapper: 步骤 5 中的图像 3,3
    • Disconnect the flapper from the posts on each side of the overflow tube.
    • Remove the flapper from the toilet tank.
结论
7等其他人完成本指南。
Kristen Gismondi
于11/12/14注册
106,091 声望
创作了267篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了25,692篇指南
2指南评论
Thank you I needed that
My Mama - 回复 分享
How universal is the flapper size? Do I need to measure the existing one before buying a replacement?
John Clements - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 79
过去 30 天: 337
总计 18,174
