跳转到主内容
Tofu65 Keyboard PCB Replacement
你所需要的
  1. Tofu65 Keyboard PCB Replacement, Keyboard PCB: 步骤 1 中的图像 1,1
    • Unplug the power cord.
  2. Tofu65 Keyboard PCB Replacement: 步骤 2 中的图像 1,1
    • Use a keycap puller to remove the keycaps from the keyboard.
    • Be sure to pull straight up when removing the keycaps to avoid damaging the key switches.
  3. Tofu65 Keyboard PCB Replacement: 步骤 3 中的图像 1,1
    • Use the switch puller to pinch the switch on the two pins to release the switch from the PCB.
    • Pull straight up when removing the switch. It should not take much force to pull them out.
  4. Tofu65 Keyboard PCB Replacement: 步骤 4 中的图像 1,2 Tofu65 Keyboard PCB Replacement: 步骤 4 中的图像 2,2
    • Remove the plastic cover that protects the PCB.
  5. Tofu65 Keyboard PCB Replacement: 步骤 5 中的图像 1,2 Tofu65 Keyboard PCB Replacement: 步骤 5 中的图像 2,2
    • Gently remove the foam layer protecting the PCB.
  6. Tofu65 Keyboard PCB Replacement: 步骤 6 中的图像 1,3 Tofu65 Keyboard PCB Replacement: 步骤 6 中的图像 2,3 Tofu65 Keyboard PCB Replacement: 步骤 6 中的图像 3,3
    • Use a Phillips #000 screwdriver to remove the six 5 mm screws keeping the PCB in place.
  7. Tofu65 Keyboard PCB Replacement: 步骤 7 中的图像 1,2 Tofu65 Keyboard PCB Replacement: 步骤 7 中的图像 2,2
    • Remove the old PCB from the bottom case.
  8. Tofu65 Keyboard PCB Replacement: 步骤 8 中的图像 1,2 Tofu65 Keyboard PCB Replacement: 步骤 8 中的图像 2,2
    • Ensure your keyboard switches are in good condition and the golden pins are not bent.
    • If the pins are bent, carefully bend them so they are straight or replace them with new switches.
  9. Tofu65 Keyboard PCB Replacement: 步骤 9 中的图像 1,3 Tofu65 Keyboard PCB Replacement: 步骤 9 中的图像 2,3 Tofu65 Keyboard PCB Replacement: 步骤 9 中的图像 3,3
    • Replace your PCB.
    • Place the foam and plastic plate cover back.
    • Line up the key switch pins with the sockets on the PCB before installing them.
    • Install the keyboard switches and apply a small amount of force to ensure they make contact with the PCB.
  10. Tofu65 Keyboard PCB Replacement: 步骤 10 中的图像 1,2 Tofu65 Keyboard PCB Replacement: 步骤 10 中的图像 2,2
    • Replace each keycaps onto the appropriate switch.
    • Press down firmly on each to ensure they are making contact.
终点
另外一个人完成了本指南。
Daniel Payan
于03/05/24注册
202 声望
撰写一个指南
团队
CSU Los Angeles, Team 2-2, Grodsky Spring 2024 CSU Los Angeles, Team 2-2, Grodsky Spring 2024 的会员
CSULA-GRODSKY-S24S2G2
2 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 65
总计 808
