跳转到主内容
Tofu65 Key Switch Replacement
你所需要的
  1. Tofu65 Key Switch Replacement, Key Switch: 步骤 1 中的图像 1,1
    • Unplug the power cord.
  2. Tofu65 Key Switch Replacement: 步骤 2 中的图像 1,1
    • Remove the keycap by using a dedicated keycap remover or creating a hook-like tool with paperclips or using other tools.
    • Ensure that you pull it straight up without damaging the switch.
  3. Tofu65 Key Switch Replacement: 步骤 3 中的图像 1,2 Tofu65 Key Switch Replacement: 步骤 3 中的图像 2,2
    • Clean the keycap either by swabbing the inside and outside with a wet cotton swab or submerging the keycap in a small container with warm water for 30 minutes.
    • Hand/dish soap can be used as well but not necessary.
    • Dry the keycaps.
    • DO NOT leave the keycaps in sunlight or else they could warp.
  4. Tofu65 Key Switch Replacement: 步骤 4 中的图像 1,1
    • In order to remove the switch, locate the two switch housing pins near the top and bottom of the switch that hold it in the keyboard plate.
  5. Tofu65 Key Switch Replacement: 步骤 5 中的图像 1,1
    • The switch can be removed with a dedicated switch remover or two small flat head screwdrivers.
    • Pinch the dedicated switch remover tool on the two housing pins or push them in with the two screwdrivers.
  6. Tofu65 Key Switch Replacement: 步骤 6 中的图像 1,1
    • The switch should become loose.
    • Pull the switch straight up and out of the socket.
  7. Tofu65 Key Switch Replacement: 步骤 7 中的图像 1,1
    • Before replacing the switch, ensure that the new switch does not have any bent pins.
    • If the pins are bent on the new switch, carefully bend them back so that they are pointing straight.
  8. Tofu65 Key Switch Replacement: 步骤 8 中的图像 1,2 Tofu65 Key Switch Replacement: 步骤 8 中的图像 2,2
    • Line up the pins with the sockets on the keyboard.
  9. Tofu65 Key Switch Replacement: 步骤 9 中的图像 1,1
    • Firmly push straight down.
    • The switch should click into place and should fit tightly in the keyboard plate.
    • Ensure that it is level and flush.
  10. Tofu65 Key Switch Replacement: 步骤 10 中的图像 1,2 Tofu65 Key Switch Replacement: 步骤 10 中的图像 2,2
    • Pop the respective keycaps back onto the switch by pushing straight down and firmly so that the cap fits all the way onto the switch.
    • Make sure that there is no residual moisture as any moisture can leak into the keyboard and cause water damage/break the entire keyboard.
终点
另外一个人完成了本指南。
Hanlin Chen
于01/31/23注册
181 声望
撰写一个指南
团队
UC Davis, Team 1-3, Morris Winter 2023 UC Davis, Team 1-3, Morris Winter 2023 的会员
UCD-MORRIS-W23S1G3
2 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 399
