当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove the two 4mm by 8mm screws from the back of the toaster oven.
Remove the four 4mm by 8mm screws from the black supports from the base of the toaster oven.
Take the two supports off of the bottom.
Remove the two 4mm by 4mm screws from the base in order to remove the tray.
Slide the back panel off of the oven.
Grip the sides of the metal cover and lift the cover up off the toaster oven top.
The knob is missing in the first picture.
Push the knob into the hole.
The knob is now back in place in the last picture.
取消:我没有完成这个指南。
与4其他贡献者
于09/26/17注册
101 声望
撰写一个指南
徽章: 2
MTU-GALLIAH-F17S5G25
1 名成员
创作了1篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 29
总计 1,853
