跳转到主内容
Tivax MiTraveler 10Q-8 Rear Case Replacement
你所需要的
  1. Tivax MiTraveler 10Q-8 Rear Case Replacement, Rear Case: 步骤 1 中的图像 1,2 Tivax MiTraveler 10Q-8 Rear Case Replacement, Rear Case: 步骤 1 中的图像 2,2
    • With the device face down, slide the charging port cover off on the left side of device.
  2. Tivax MiTraveler 10Q-8 Rear Case Replacement: 步骤 2 中的图像 1,1
    • Locate a Phillips 2.88mm screw at the charging port.
  3. Tivax MiTraveler 10Q-8 Rear Case Replacement: 步骤 3 中的图像 1,1
    • Use a PH000 Philips head screwdriver to remove screw.
    • Remember lefty loosey, righty tighty
  4. Tivax MiTraveler 10Q-8 Rear Case Replacement: 步骤 4 中的图像 1,1
    • To pry the back plate off, use the plastic opening tool between the back plate and front plate; start at the headphone jack.
    • Make sure the lip of the plastic opening tool is face up.
  5. Tivax MiTraveler 10Q-8 Rear Case Replacement: 步骤 5 中的图像 1,2 Tivax MiTraveler 10Q-8 Rear Case Replacement: 步骤 5 中的图像 2,2
    • Move around the device with the plastic opening tool, pushing down to release the back plate from clips.
    • You will hear popping sounds when you work around the device.
  6. Tivax MiTraveler 10Q-8 Rear Case Replacement: 步骤 6 中的图像 1,2 Tivax MiTraveler 10Q-8 Rear Case Replacement: 步骤 6 中的图像 2,2
    • Once you’ve moved around the whole device with the plastic opening tool, the back plate will completely release from the rest of the device.
结论
To reassemble your device, simply slide the back plate back in to place and press down until you hear several clicks.
Maria
于03/16/15注册
210 声望
创作了2篇指南
团队
Colorado Springs, Team 4-3, Panko Spring 2015 Colorado Springs, Team 4-3, Panko Spring 2015 的会员
UCCS-PANKO-S15S4G3
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 300
