跳转到主内容
Titan Airless Sprayer IMPACT 410 Capacitor Replacement
你所需要的
  1. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Safety precautions: 步骤 1 中的图像 1,2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Safety precautions: 步骤 1 中的图像 2,2
    • Before you begin, make sure to follow the pressure relief procedure documented in the user manual before powering down the paint sprayer and disconnecting the pump.
    • Turn off and unplug the sprayer.
  2. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Unfasten the motor cover: 步骤 2 中的图像 1,2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Unfasten the motor cover: 步骤 2 中的图像 2,2
    • Use a Phillips driver to remove the four 12 mm-long screws (two on either side) securing the motor cover.
  3. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the motor cover: 步骤 3 中的图像 1,3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the motor cover: 步骤 3 中的图像 2,3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the motor cover: 步骤 3 中的图像 3,3
    • Pull the motor cover straight off the motor.
  4. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor wires: 步骤 4 中的图像 1,3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor wires: 步骤 4 中的图像 2,3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor wires: 步骤 4 中的图像 3,3
    • Use diagonal cutters, or scissors, to cut the two cable ties bundling the capacitor's positive and negative wires.
    • During reassembly, replace the cable ties.
  5. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the negative wire: 步骤 5 中的图像 1,2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the negative wire: 步骤 5 中的图像 2,2
    • Disconnect the black negative wire's spade connector.
    • Always grip cables by their connectors and not the wires themselves.
  6. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the positive wire: 步骤 6 中的图像 1,2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the positive wire: 步骤 6 中的图像 2,2
    • Disconnect the red positive wire's bullet connector.
  7. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor: 步骤 7 中的图像 1,3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor: 步骤 7 中的图像 2,3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor: 步骤 7 中的图像 3,3
    • Grip the cable tie and slide it off the capacitors.
  8. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Discharge the capacitors: 步骤 8 中的图像 1,1
    • If you have already discharged the capacitors, skip this step.
    • Follow this guide to discharge your capacitors.
  9. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the capacitors: 步骤 9 中的图像 1,2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the capacitors: 步骤 9 中的图像 2,2
    • The capacitors are lightly adhered to the motor body.
    • Insert a flathead screwdriver underneath the capacitors, between the bottom cell and the adhesive.
    • Pry up to separate the bottom cell from the motor body.
  10. Titan Airless Sprayer IMPACT 410 Capacitor Replacement: 步骤 10 中的图像 1,3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement: 步骤 10 中的图像 2,3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement: 步骤 10 中的图像 3,3
    • Insert a flathead screwdriver underneath the capacitors, between the top cell and the adhesive.
    • Pry up to separate the rest of the capacitor from the motor body.
    • Remove the capacitor.
    • During reassembly, if the adhesive is no longer sticky, replace it with double-sided foam adhesive.
结论
另外一个人完成了本指南。
Alex Diaz-Kokaisl
于01/16/22注册
124,924 声望
创作了582篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,400篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 12
总计 291
