跳转到主内容
Tineco FLOOR ONE S3 Breeze Wheels Replacement
你所需要的
  1. Tineco FLOOR ONE S3 Breeze Wheels Replacement, Brush Roller: 步骤 1 中的图像 1,2 Tineco FLOOR ONE S3 Breeze Wheels Replacement, Brush Roller: 步骤 1 中的图像 2,2
    • Place a finger on the lever located on the brush roller cover.
    • Firmly push the lever with a finger to remove the brush roller cover.
  2. Tineco FLOOR ONE S3 Breeze Wheels Replacement: 步骤 2 中的图像 1,1
    • Grasp the brush roller on its side.
    • Pull the brush roller out of its initial position.
  3. Tineco FLOOR ONE S3 Breeze Wheels Replacement, Wheels: 步骤 3 中的图像 1,2 Tineco FLOOR ONE S3 Breeze Wheels Replacement, Wheels: 步骤 3 中的图像 2,2
    • Remove four 10.6 mm screws from the plastic cover with a Phillips #1 screwdriver.
    • Remove the first plastic cover.
  4. Tineco FLOOR ONE S3 Breeze Wheels Replacement: 步骤 4 中的图像 1,2 Tineco FLOOR ONE S3 Breeze Wheels Replacement: 步骤 4 中的图像 2,2
    • Remove twelve 10.6 mm screws from the second plastic cover with a Phillips #1 screwdriver.
    • Remove the second plastic cover.
  5. Tineco FLOOR ONE S3 Breeze Wheels Replacement: 步骤 5 中的图像 1,2 Tineco FLOOR ONE S3 Breeze Wheels Replacement: 步骤 5 中的图像 2,2
    • Remove two 10.6 mm screws holding the wheels in place with a Phillips #1 screwdriver.
    • Remove the wheels.
    • The wheels do not need to be removed to access the motor.
结论
Luke Guess
于02/14/24注册
193 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 5
过去 30 天: 13
总计 55
