跳转到主内容
Timbuk2 Pannier Bottom Stay Bracket Replacement
你所需要的
  1. Timbuk2 Pannier Bottom Stay Bracket Replacement, Bottom Stay Bracket: 步骤 1 中的图像 1,1
    • Tools needed:
    • New Pannier Bottom Stay Bracket.
    • Standard Screwdriver
    • Wrench
  2. Timbuk2 Pannier Bottom Stay Bracket Replacement: 步骤 2 中的图像 1,2 Timbuk2 Pannier Bottom Stay Bracket Replacement: 步骤 2 中的图像 2,2
    • To remove bottom stay bracket, first unscrew all 4 screws. To do so, undo velcro flap located at the top of the laptop sleeve. With the wrench, hold nut in place in the back of the pannier, while using the screwdriver to unscrew the screw in the front bracket.
  3. Timbuk2 Pannier Bottom Stay Bracket Replacement: 步骤 3 中的图像 1,1
    • Remove old clip. Take new bottom bracket and remove all screws and washers from bracket (Make sure to put all screws, washers, and nuts in a safe place (Ziploc bag) as to not lose any!)
    • Follow step 2 in reverse order to attach new clip bracket. (Hold nut with wrench while screwing back in place. Also make sure the washers are between the screws and the body of the bag.)
  4. Timbuk2 Pannier Bottom Stay Bracket Replacement: 步骤 4 中的图像 1,1
    • All Done!
终点
Emilee
于03/13/14注册
1,591 声望
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 395
