跳转到主内容
加入维修社区 - 创建账户
本篇指南是分解流程而非维修指南。 如果您要维修您的Tile Sticker,应参考我们的维修指南
  1. Tile Sticker Teardown, Tile Sticker Teardown: 步骤 1 中的图像 1,1
    • Use a spudger or flathead screwdriver to remove the outer ring
    • I removed the rubber button cover as well, but this is not necessary.
  2. Tile Sticker Teardown: 步骤 2 中的图像 1,1
    • Use a flathead screwdriver to pry the two halves of the case apart from each other
    • The technique I used is to find a small hole in the casing and use a very small flathead screwdriver with upward/downward force.
  3. Tile Sticker Teardown: 步骤 3 中的图像 1,1
    • Pull the electronics out of the casing.
  4. Tile Sticker Teardown: 步骤 4 中的图像 1,1
    • At the bottom is the power source - A soldered-in CR2032 battery.
  5. Tile Sticker Teardown: 步骤 5 中的图像 1,1
    • Hidden away in the top casing is a piezoelectric speaker.
  6. Tile Sticker Teardown: 步骤 6 中的图像 1,1
    • The main chips:
    • 240 C29
    • N(RF)52810 CAAAD0 1928AE
Andrew S
于07/30/21注册
15,457 声望
创作了8篇指南
8指南评论
I’m glad I was not the only one who tried this, but you had much more success than me. We used to use ours for the remote to the TV which gets lost often and then the battery died and I refused to believe it was not user replaceable. Unfortunately I didn’t have much luck actually getting past step 1 since the two halves staunchly refused to come apart. So I murdered it in frustration and threw it in the bin.
Alisha C - 回复
Yep, mine lasted a little less than 2 years. The key to getting the two casing halves apart is to use a really small flathead screwdriver and put it in one of the holes in the casing, then start pushing downwards.
Andrew S -
So I got it open, desoldered the battery, resoldered a new one - and it turns on and beeps with a double tap… doesn’t ack its location, can’t be dinged from the app… can’t activate it because it says it’s already activated (duh) - but it’s been off for > 760 days according to Tile. Pretty sure they have a “drop dead” condition or some ultimate expiration date on the ones with soldered batteries (this forcing you to get new ones). AirTags for me from now on (I just wish they were louder)
Dave Miller - 回复
Scratch that! After repeatedly clicking - it’s now working again… huzzah!
Dave Miller - 回复
Glad to hear you had success in replacing the battery inside your Tile Sticker!
Andrew S -
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 32
过去 30 天: 137
总计 10,967
