当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Power down the TiVo and detach the power cable from the rear of the unit.
Wait 5 minutes for the unit to fully discharge before proceeding to the next step.
Remove the five T10 screws from the rear of the case using the Torx screwdriver.
Lift up and pull back the outer casing towards the rear of the unit.
Carefully remove the ribbon cable from the power supply. Hold the ribbon on both sides and pull up.
Disconnect the hard drive power cable. Firmly grip the white power connector and pull away from the hard drive.
Do not pull on the power cables when disconnecting power connector.
Rotate the device 180 degrees and remove the two T10 screws from the power supply board.
Remove the four plastic standoffs.
Use pliers to squeeze the plastic pieces on the head together. Carefully press down on the standoff and pull up on the power supply.
Lift the power supply out of the unit.
Do not touch any circuit elements or capacitors on the power supply, as they may hold a charge after the unit has been shut off.
取消:我没有完成这个指南。
2等其他人完成本指南。
与9其他贡献者
于04/16/10注册
135 声望
创作了5篇指南
徽章: 8
+ 5更多徽章
CPSU-JOHANN-S10S33G79
4 名成员
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 8
总计 5,168
