跳转到主内容
TiVo Series 2 TCD540080 Power Supply Replacement
你所需要的
  1. TiVo Series 2 TCD540080 Power Supply Replacement, Removal of TiVo Series 2 TCD540080 Case: 步骤 1 中的图像 1,1
    • Power down the TiVo and detach the power cable from the rear of the unit.
    • Wait 5 minutes for the unit to fully discharge before proceeding to the next step.
  2. TiVo Series 2 TCD540080 Power Supply Replacement: 步骤 2 中的图像 1,1
    • Remove the five T10 screws from the rear of the case using the Torx screwdriver.
  3. TiVo Series 2 TCD540080 Power Supply Replacement: 步骤 3 中的图像 1,2 TiVo Series 2 TCD540080 Power Supply Replacement: 步骤 3 中的图像 2,2
    • Lift up and pull back the outer casing towards the rear of the unit.
  4. TiVo Series 2 TCD540080 Power Supply Replacement, Power Supply: 步骤 4 中的图像 1,2 TiVo Series 2 TCD540080 Power Supply Replacement, Power Supply: 步骤 4 中的图像 2,2
    • Carefully remove the ribbon cable from the power supply. Hold the ribbon on both sides and pull up.
  5. TiVo Series 2 TCD540080 Power Supply Replacement: 步骤 5 中的图像 1,1
    • Disconnect the hard drive power cable. Firmly grip the white power connector and pull away from the hard drive.
    • Do not pull on the power cables when disconnecting power connector.
  6. TiVo Series 2 TCD540080 Power Supply Replacement: 步骤 6 中的图像 1,1
    • Rotate the device 180 degrees and remove the two T10 screws from the power supply board.
  7. TiVo Series 2 TCD540080 Power Supply Replacement: 步骤 7 中的图像 1,2 TiVo Series 2 TCD540080 Power Supply Replacement: 步骤 7 中的图像 2,2
    • Remove the four plastic standoffs.
    • Use pliers to squeeze the plastic pieces on the head together. Carefully press down on the standoff and pull up on the power supply.
  8. TiVo Series 2 TCD540080 Power Supply Replacement: 步骤 8 中的图像 1,2 TiVo Series 2 TCD540080 Power Supply Replacement: 步骤 8 中的图像 2,2
    • Lift the power supply out of the unit.
    • Do not touch any circuit elements or capacitors on the power supply, as they may hold a charge after the unit has been shut off.
结论
2等其他人完成本指南。
团队
Cal Poly, Team 33-79, Johann Spring 2010 Cal Poly, Team 33-79, Johann Spring 2010 的会员
CPSU-JOHANN-S10S33G79
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 5,182
