当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Power down the TiVo and detach the power cable from the rear of the unit.
Wait 5 minutes for the unit to fully discharge before proceeding to the next step.
Remove the five T10 screws from the rear of the case using the Torx screwdriver.
Lift up and pull back the outer casing towards the rear of the unit.
On the rear of the device, remove the right screw with a T10 Torx Screwdriver.
Unscrew the two black screws on the left with a T8 Torx Screwdriver.
Disconnect the white ribbon cable from the motherboard.
The black base where the cable is connected is not part of the cable. Do not lift up on it!
Remove fan power connector.
Disconnect the hard drive data cable.
Use extreme caution when unplugging the connector and do not disconnect the data cable by pulling on the cable itself.
Disconnect the connector cable that goes to the lights on the front of the device.
Unscrew the four screws on the motherboard with a T10 screwdriver.
Use a pair of needle-nose pliers to make the two tabs parallel with the open slots.
It is recommended that you do not bend these back after putting unit back together as they may break after repeated use.
Pull the motherboard out towards the front of the TiVo unit, then pull up to remove it.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与5其他贡献者
于04/16/10注册
135 声望
创作了5篇指南
徽章: 8
+ 5更多徽章
CPSU-JOHANN-S10S33G79
4 名成员
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 4,414
