跳转到主内容
TiVo Series 2 TCD540080 Motherboard Replacement
你所需要的
  1. TiVo Series 2 TCD540080 Motherboard Replacement, Removal of TiVo Series 2 TCD540080 Case: 步骤 1 中的图像 1,1
    • Power down the TiVo and detach the power cable from the rear of the unit.
    • Wait 5 minutes for the unit to fully discharge before proceeding to the next step.
  2. TiVo Series 2 TCD540080 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the five T10 screws from the rear of the case using the Torx screwdriver.
  3. TiVo Series 2 TCD540080 Motherboard Replacement: 步骤 3 中的图像 1,2 TiVo Series 2 TCD540080 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Lift up and pull back the outer casing towards the rear of the unit.
  4. TiVo Series 2 TCD540080 Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,1
    • On the rear of the device, remove the right screw with a T10 Torx Screwdriver.
    • Unscrew the two black screws on the left with a T8 Torx Screwdriver.
  5. TiVo Series 2 TCD540080 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Disconnect the white ribbon cable from the motherboard.
    • The black base where the cable is connected is not part of the cable. Do not lift up on it!
  6. TiVo Series 2 TCD540080 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove fan power connector.
  7. TiVo Series 2 TCD540080 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Disconnect the hard drive data cable.
    • Use extreme caution when unplugging the connector and do not disconnect the data cable by pulling on the cable itself.
  8. TiVo Series 2 TCD540080 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Disconnect the connector cable that goes to the lights on the front of the device.
  9. TiVo Series 2 TCD540080 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Unscrew the four screws on the motherboard with a T10 screwdriver.
  10. TiVo Series 2 TCD540080 Motherboard Replacement: 步骤 10 中的图像 1,3 TiVo Series 2 TCD540080 Motherboard Replacement: 步骤 10 中的图像 2,3 TiVo Series 2 TCD540080 Motherboard Replacement: 步骤 10 中的图像 3,3
    • Use a pair of needle-nose pliers to make the two tabs parallel with the open slots.
    • It is recommended that you do not bend these back after putting unit back together as they may break after repeated use.
  11. TiVo Series 2 TCD540080 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Pull the motherboard out towards the front of the TiVo unit, then pull up to remove it.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 33-79, Johann Spring 2010 Cal Poly, Team 33-79, Johann Spring 2010 的会员
CPSU-JOHANN-S10S33G79
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 17
总计 4,455
