跳转到主内容
TiVo Series 2 TCD540080 Cooling Fan Replacement
你所需要的
  1. TiVo Series 2 TCD540080 Cooling Fan Replacement, Removal of TiVo Series 2 TCD540080 Case: 步骤 1 中的图像 1,1
    • Power down the TiVo and detach the power cable from the rear of the unit.
    • Wait 5 minutes for the unit to fully discharge before proceeding to the next step.
  2. TiVo Series 2 TCD540080 Cooling Fan Replacement: 步骤 2 中的图像 1,1
    • Remove the five T10 screws from the rear of the case using the Torx screwdriver.
  3. TiVo Series 2 TCD540080 Cooling Fan Replacement: 步骤 3 中的图像 1,2 TiVo Series 2 TCD540080 Cooling Fan Replacement: 步骤 3 中的图像 2,2
    • Lift up and pull back the outer casing towards the rear of the unit.
  4. TiVo Series 2 TCD540080 Cooling Fan Replacement, Cooling Fan: 步骤 4 中的图像 1,1
    • The fan is held in by four T15 screws on the rear of the device.
  5. TiVo Series 2 TCD540080 Cooling Fan Replacement: 步骤 5 中的图像 1,2 TiVo Series 2 TCD540080 Cooling Fan Replacement: 步骤 5 中的图像 2,2
    • Take the wound red and black wires coming from the fan and follow them back to the logic board.
    • Unplug the connector from the motherboard.
  6. TiVo Series 2 TCD540080 Cooling Fan Replacement: 步骤 6 中的图像 1,2 TiVo Series 2 TCD540080 Cooling Fan Replacement: 步骤 6 中的图像 2,2
    • Pull the fan towards the front and out of the TiVo unit.
结论
团队
Cal Poly, Team 33-79, Johann Spring 2010 Cal Poly, Team 33-79, Johann Spring 2010 的会员
CPSU-JOHANN-S10S33G79
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 5,261
