当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Unscrew the five 0.31 inch T-9 screws on the back cover.
Slide the cover towards the back until it is no longer under the front cover.
Lift the cover up and off the device.
Unplug the ribbon cable from the motherboard. Some force may be required for this step, so be careful not to rip the ribbon cable.
Unscrew the two 0.31 inch T-9 screws on the inside of the front cover.
Use a spudger to push the three tabs on the inside of the front cover up and forward to release the cover.
Pull the front cover down and away from the device to separate it completely. Be careful not to tear the ribbon cable as you are removing the front cover.
Unscrew the two 0.31 inch T-9 screws on the back of the sensor.
Lift the sensor up to remove it.
取消:我没有完成这个指南。
与5其他贡献者
于10/10/11注册
37 声望
创作了2篇指南
徽章: 8
+ 5更多徽章
CPSU-AMIDO-F11S5G33
4 名成员
创作了7篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 7
总计 1,016
