跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
The Motherboard contains all the 'brains' of the device. In case this component needs to be replaced, this guide will walk you through the installation of the motherboard.
  1. Unscrew the five 0.31 inch T-9 screws on the back cover.
    • Unscrew the five 0.31 inch T-9 screws on the back cover.
  2. Slide the cover towards the back until it is no longer under the front cover.
    • Slide the cover towards the back until it is no longer under the front cover.
  3. Lift the cover up and off the device.
    • Lift the cover up and off the device.
  4. Unscrew the 0.31 inch T-9 size screw on the back panel
    • Unscrew the 0.31 inch T-9 size screw on the back panel
    • Unscrew the two 0.59 inch T-8 size screws on the back panel
  5. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  6. Unplug the fan from the motherboard by gently pulling up on the red plug.
    • Unplug the fan from the motherboard by gently pulling up on the red plug.
  7. Unplug the ribbon attaching the front panel sensor by pulling it upwards gently.
    • Unplug the ribbon attaching the front panel sensor by pulling it upwards gently.
  8. Unplug the ribbon connecting the hard drive to the motherboard by pulling straight up on the ribbon. This may require some gentle wiggling.
    • Unplug the ribbon connecting the hard drive to the motherboard by pulling straight up on the ribbon. This may require some gentle wiggling.
  9. Unplug the ribbon connecting the power supply to the motherboard by pulling upwards on this ribbon.
    • Unplug the ribbon connecting the power supply to the motherboard by pulling upwards on this ribbon.
  10. Locate the four metal tabs on the motherboard. Using Pliers, bend each of the tabs until they align straight with the holes underneath them.
    • Locate the four metal tabs on the motherboard.
    • Using Pliers, bend each of the tabs until they align straight with the holes underneath them.
    • Bend these just enough to slip them through the holes. Over-bending could snap these tabs. While this won't affect how the TiVo functions, they are there to secure the motherboard to prevent damage.
  11. Locate and remove the four 0.31 inch T-9 size screws at the front of the motherboard.
    • Locate and remove the four 0.31 inch T-9 size screws at the front of the motherboard.
  12. Pull directly up on the motherboard so that it slips over the four golden metal tabs. Pull up and away from the back panel so all of the cable inputs slip through the casing.
    • Pull directly up on the motherboard so that it slips over the four golden metal tabs.
    • Pull up and away from the back panel so all of the cable inputs slip through the casing.
结论
Cody Hunter
于2011年10月10日注册
22 信誉积分
创作了2篇指南
团队
Cal Poly, Team 5-33, Amido Fall 2011 Cal Poly, Team 5-33, Amido Fall 2011 的会员
CPSU-AMIDO-F11S5G33
4 名成员
创作了7篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 998
