跳转到主内容
修复你的物品
维修的权力
商店
简介
The battery acts as an internal power source for the device. In case this battery needs to be replaced, this simple guide will walk you through the steps of removing the current battery to replace it.
配件
没有特定配件。
  1. Unscrew the five 0.31 inch T-9 screws on the back cover.
    • Unscrew the five 0.31 inch T-9 screws on the back cover.
  2. Slide the cover towards the back until it is no longer under the front cover.
    • Slide the cover towards the back until it is no longer under the front cover.
  3. Essential 工具包
    我们最紧凑的套装中最有用的工具。
    现在开始购物
    Essential 工具包
    我们最紧凑的套装中最有用的工具。
    现在开始购物
  4. Lift the cover up and off the device.
    • Lift the cover up and off the device.
  5. Locate the battery on the motherboard.
    • Locate the battery on the motherboard.
  6. Using the spudger, wedge the metal clip off of the top surface of the battery.
    • Using the spudger, wedge the metal clip off of the top surface of the battery.
  7. Use your finger to push the battery sideways out of its holder.
    • Use your finger to push the battery sideways out of its holder.
结论
Cody Hunter
于2011年10月10日注册
22 信誉积分
创作了2篇指南
团队
Cal Poly, Team 5-33, Amido Fall 2011 Cal Poly, Team 5-33, Amido Fall 2011 的会员
CPSU-AMIDO-F11S5G33
4 名成员
创作了7篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 7
总计 1,440
