跳转到主内容
简介
This guide will show you how to replace the connection port for the pedals.
  1. Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Remove the black 10mm using a JIS #1 screw driver.
    • There are 12 screws.
    • Two of the screws are deep inside the device you might need to use a slim screwdriver.
    • In the picture you see a plastic opening tool instead of screw driver because we did not have our screw driver when we were taking the picture.
  2. Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement: 步骤 2 中的图像 1,2 Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement: 步骤 2 中的图像 2,2
    • Remove the two 10mm black screws on the top of device using a Hex 2.5mm Key. Only the two outside screws.
    • Gently pull apart both halves of device to access inside.
  3. Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement, Wheel and Pedal Connection Port: 步骤 3 中的图像 1,2 Thustmaster Ferrari 458 Spider Racing Wheel and Pedal Connection Port Replacement, Wheel and Pedal Connection Port: 步骤 3 中的图像 2,2
    • Using a small plastic opening tool, gently pry up the white connector that connects the pedals to the board.
    • By pulling up on both ends of the port you will be able to pull out the port to remove it.
结论
2等其他人完成本指南。
Mario Nunez
于2017年10月18日注册
403 声望
创作了3篇指南
团队
USF Tampa, Team S1-G33, Cagle Fall 2017 USF Tampa, Team S1-G33, Cagle Fall 2017 的会员
USFT-CAGLE-F17S1G33
4 名成员
创作了5篇指南
2条评论
I just need to know where to get a replacement USB cable from ( the USB to the circular end part).
TheComfyCompie - 回复
I need to know what USB cable connects the round cable end on the steerwheel to the Xbox one
Susan Witter - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 68
总计 4,440
