跳转到主内容
Thustmaster Ferrari 458 Spider Racing Wheel Gas/Break Pedal Replacement
你所需要的
  1. Thustmaster Ferrari 458 Spider Racing Wheel Gas/Break Pedal Replacement, Gas/Break Pedal: 步骤 1 中的图像 1,3 Thustmaster Ferrari 458 Spider Racing Wheel Gas/Break Pedal Replacement, Gas/Break Pedal: 步骤 1 中的图像 2,3 Thustmaster Ferrari 458 Spider Racing Wheel Gas/Break Pedal Replacement, Gas/Break Pedal: 步骤 1 中的图像 3,3
    • Start by removing both pedals. Remove the two black 20mm screws on each pedal using a PH2 Phillips head screw driver.
    • In the picture you see a plastic opening tool instead of screw driver because we did not have our screw driver when we were taking the picture.
  2. Thustmaster Ferrari 458 Spider Racing Wheel Gas/Break Pedal Replacement: 步骤 2 中的图像 1,3 Thustmaster Ferrari 458 Spider Racing Wheel Gas/Break Pedal Replacement: 步骤 2 中的图像 2,3 Thustmaster Ferrari 458 Spider Racing Wheel Gas/Break Pedal Replacement: 步骤 2 中的图像 3,3
    • Remove the 10mm long black screws on the back of the base using a PH2 Phillips head screw driver. There are 13 screws total.
    • Gently lift cover out to access inside.
    • There is a screw behind the cable.
    • In the picture you see a plastic opining tool instead of screw driver because we did not have our screw driver when we were taking the picture.
  3. Thustmaster Ferrari 458 Spider Racing Wheel Gas/Break Pedal Replacement: 步骤 3 中的图像 1,2 Thustmaster Ferrari 458 Spider Racing Wheel Gas/Break Pedal Replacement: 步骤 3 中的图像 2,2
    • Push the pin that holds the pedal out from middle outward.
    • There are two springs that hold the pedal upward. Make sure the pin goes through the springs and the pedal when installing new pedal.
  4. Thustmaster Ferrari 458 Spider Racing Wheel Gas/Break Pedal Replacement: 步骤 4 中的图像 1,1
    • Install the new pedal with springs and pin and make sure that the pin holds them together.
    • Add a little grease on pin when installing the new pedal.
    • Repeat steps in reverse to reassemble device.
    • Wash your hands after you finish dealing with grease. it is a dangerous material will cause problems if it gets in your eyes or get swallowed.
结论
2等其他人完成本指南。
Mario Nunez
于10/18/17注册
421 声望
创作了3篇指南
团队
USF Tampa, Team S1-G33, Cagle Fall 2017 USF Tampa, Team S1-G33, Cagle Fall 2017 的会员
USFT-CAGLE-F17S1G33
4 名成员
创作了5篇指南
6条评论
Hi, where can you get replacement springs? Cannot find anything online that sells this specific diameter and angle at both ends? Can I contact Thrustmaster to get more springs or a replacement pedal set?
Alex Ruiz - 回复
I am also looking for this spring. Any help would be appreciated.
thanks
Maxime Viens -
Me too. Are these springs available?
Jay Nicholson - 回复
I only need 1 spring, not 10....
Anyone selling 1 spring?
fnaf master101 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 27
过去 30 天: 76
总计 11,555
