跳转到主内容
Thustmaster Ferrari 458 Spider Racing Wheel Bottom Cover Replacement
你所需要的
  1. Thustmaster Ferrari 458 Spider Racing Wheel Bottom Cover Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Remove the black 10mm using a JIS #1 screw driver.
    • There are 12 screws.
    • Two of the screws are deep inside the device you might need to use a slim screwdriver.
    • In the picture you see a plastic opening tool instead of screw driver because we did not have our screw driver when we were taking the picture.
  2. Thustmaster Ferrari 458 Spider Racing Wheel Bottom Cover Replacement: 步骤 2 中的图像 1,2 Thustmaster Ferrari 458 Spider Racing Wheel Bottom Cover Replacement: 步骤 2 中的图像 2,2
    • Remove the two 10mm black screws on the top of device using a Hex 2.5mm Key. Only the two outside screws.
    • Gently pull apart both halves of device to access inside.
结论
2等其他人完成本指南。
团队
USF Tampa, Team S1-G33, Cagle Fall 2017 USF Tampa, Team S1-G33, Cagle Fall 2017 的会员
USFT-CAGLE-F17S1G33
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 21
总计 5,466
