跳转到主内容
Thrustmaster T3PM RJ12 main cable Replacement
你所需要的
  1. Thrustmaster T3PM RJ12 main cable Replacement, Disconnect the pedal heads: 步骤 1 中的图像 1,2 Thrustmaster T3PM RJ12 main cable Replacement, Disconnect the pedal heads: 步骤 1 中的图像 2,2
    • Unscrew all 6 screws from the pedal heads
    • Note the positioning of the pedal heads or take this opportunity to try out new position
  2. Thrustmaster T3PM RJ12 main cable Replacement, Remove screws from the bottom: 步骤 2 中的图像 1,1
    • Use a Phillips driver to remove all screws at the bottom.
    • Keep track of each screw as to not loose it.
  3. Thrustmaster T3PM RJ12 main cable Replacement, Remove the top cover: 步骤 3 中的图像 1,1
    • Remove the top cover and put it aside
  4. Thrustmaster T3PM RJ12 main cable Replacement, Disconnect the wires from pedal sensors: 步骤 4 中的图像 1,3 Thrustmaster T3PM RJ12 main cable Replacement, Disconnect the wires from pedal sensors: 步骤 4 中的图像 2,3 Thrustmaster T3PM RJ12 main cable Replacement, Disconnect the wires from pedal sensors: 步骤 4 中的图像 3,3
    • Use the Tweezers to carefully remove the wires from the sensors
  5. Thrustmaster T3PM RJ12 main cable Replacement, Remove tape: 步骤 5 中的图像 1,3 Thrustmaster T3PM RJ12 main cable Replacement, Remove tape: 步骤 5 中的图像 2,3 Thrustmaster T3PM RJ12 main cable Replacement, Remove tape: 步骤 5 中的图像 3,3
    • Lift the tape and remove the cable
    • You can keep the original tape, add new tape or use some other method to stabilize the cable.
  6. Thrustmaster T3PM RJ12 main cable Replacement, Replace the cable: 步骤 6 中的图像 1,2 Thrustmaster T3PM RJ12 main cable Replacement, Replace the cable: 步骤 6 中的图像 2,2
    • Carefully connect the wires of a new cable with the sensors
结论
To reassemble your pedal set, follow these instructions in reverse order.
Formica Fusca
于08/01/24注册
2,595 声望
创作了15篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 15
过去 30 天: 87
总计 1,554
