跳转到主内容
Thrustmaster T Flight Hotas 4 Trigger Replacement
你所需要的
  1. Thrustmaster T Flight Hotas 4 Trigger Replacement, J1 Screws on Joystick Handle: 步骤 1 中的图像 1,2 Thrustmaster T Flight Hotas 4 Trigger Replacement, J1 Screws on Joystick Handle: 步骤 1 中的图像 2,2
    • Be sure to disconnect the controller from the power source before disassembling.
    • Remove the four 15 mm J1 JIS head screws from the exterior of the joystick.
  2. Thrustmaster T Flight Hotas 4 Trigger Replacement, Trigger: 步骤 2 中的图像 1,3 Thrustmaster T Flight Hotas 4 Trigger Replacement, Trigger: 步骤 2 中的图像 2,3 Thrustmaster T Flight Hotas 4 Trigger Replacement, Trigger: 步骤 2 中的图像 3,3
    • Carefully remove the paneling of the joystick using your hands to pull the panels apart.
    • Be aware that the panels will fall apart when the screws are removed unless they are held together.
    • This metal piece must be put back into its correct position. If not it will impair the movement of the joystick's rudder mechanism.
  3. Thrustmaster T Flight Hotas 4 Trigger Replacement: 步骤 3 中的图像 1,1
    • Remove the 8 mm J1 JIS head screw that is holding the trigger in place.
  4. Thrustmaster T Flight Hotas 4 Trigger Replacement: 步骤 4 中的图像 1,3 Thrustmaster T Flight Hotas 4 Trigger Replacement: 步骤 4 中的图像 2,3 Thrustmaster T Flight Hotas 4 Trigger Replacement: 步骤 4 中的图像 3,3
    • Remove trigger and metal spring.
    • Remember to position the metal spring in the exact same place.
结论
Aaron Banaga
于09/11/17注册
526 声望
创作了4篇指南
团队
CSU Fullerton, Team S2-G1, Bruce Fall 2017 CSU Fullerton, Team S2-G1, Bruce Fall 2017 的会员
CSUF-BRUCE-F17S2G1
3 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 18
总计 3,388
