跳转到主内容
Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement
你所需要的
  1. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement, J1 Screws on Throttle: 步骤 1 中的图像 1,1
    • Be sure to disconnect the controller from the power source before disassembling.
    • Remove the five 15 mm J1 JIS head screws from the front of the throttle.
  2. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement, Throttle Panel: 步骤 2 中的图像 1,2 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement, Throttle Panel: 步骤 2 中的图像 2,2
    • Using your hands, pull away the panel from the throttle.
  3. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement, R2 & L2 Buttons: 步骤 3 中的图像 1,2 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement, R2 & L2 Buttons: 步骤 3 中的图像 2,2
    • Remove the two 7 mm J1 JIS head screws from the panel covering the buttons.
  4. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: 步骤 4 中的图像 1,2 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: 步骤 4 中的图像 2,2
    • Pull the panel that is covering the R2 button away from the throttle.
  5. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: 步骤 5 中的图像 1,2 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: 步骤 5 中的图像 2,2
    • Carefully push the R2 button from the outside of the panel.
    • Be cautious of the spring attached to the button as it can be easily lost.
  6. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: 步骤 6 中的图像 1,2 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: 步骤 6 中的图像 2,2
    • Remove the two 4 mm J1 JIS head screws from the panel covering the L2 button.
  7. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: 步骤 7 中的图像 1,2 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: 步骤 7 中的图像 2,2
    • Carefully push the L2 button from the outside of the panel.
结论
2等其他人完成本指南。
Crystal Nguyen
于09/11/17注册
624 声望
创作了4篇指南
团队
CSU Fullerton, Team S2-G1, Bruce Fall 2017 CSU Fullerton, Team S2-G1, Bruce Fall 2017 的会员
CSUF-BRUCE-F17S2G1
3 名成员
创作了13篇指南
一条评论
Hello, m R2 button is broken. Do you know where i can print a new one ?
louis_tiquet - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 1,295
