跳转到主内容
Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement
你所需要的
  1. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement, J1 Screws on Throttle: 步骤 1 中的图像 1,1
    • Be sure to disconnect the controller from the power source before disassembling.
    • Remove the five 15 mm J1 JIS head screws from the front of the throttle.
  2. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement, Throttle Panel: 步骤 2 中的图像 1,2 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement, Throttle Panel: 步骤 2 中的图像 2,2
    • Using your hands, pull away the panel from the throttle.
  3. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement, PlayStation Action Buttons: 步骤 3 中的图像 1,2 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement, PlayStation Action Buttons: 步骤 3 中的图像 2,2
    • Remove the two 8 mm J1 JIS head screws.
  4. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 步骤 4 中的图像 1,2 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 步骤 4 中的图像 2,2
    • Remove exterior panel from the throttle by using your hands to gently pull the panel away.
  5. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 步骤 5 中的图像 1,2 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 步骤 5 中的图像 2,2
    • Remove the two 6 mm J1 JIS head screws from the circuit board.
  6. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 步骤 6 中的图像 1,1
    • Carefully remove the circuit board.
  7. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 步骤 7 中的图像 1,2 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 步骤 7 中的图像 2,2
    • Remove the 6 mm J1 JIS head screw that is attached to the black plastic cover.
  8. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 步骤 8 中的图像 1,2 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 步骤 8 中的图像 2,2
    • Remove black plastic cover.
  9. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 步骤 9 中的图像 1,2 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 步骤 9 中的图像 2,2
    • Once the black plastic cover is removed, push the buttons inward from the outside of the device.
    • Be aware of the springs. They are small and easy to lose.
    • This step only replaces the x, square, and circle buttons.
  10. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 步骤 10 中的图像 1,2 Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 步骤 10 中的图像 2,2
    • Remove the two 6 mm J1 JIS head screws that are attached to the tan plastic cover.
    • Removal of the screws will detach the exterior panel from the device.
  11. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 步骤 11 中的图像 1,1
    • Carefully remove tan plastic cover.
  12. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: 步骤 12 中的图像 1,1
    • Once the black panel is disconnected, push the triangle button inward from the outside of the exterior panel.
结论
Aaron Banaga
于09/11/17注册
526 声望
创作了4篇指南
团队
CSU Fullerton, Team S2-G1, Bruce Fall 2017 CSU Fullerton, Team S2-G1, Bruce Fall 2017 的会员
CSUF-BRUCE-F17S2G1
3 名成员
创作了13篇指南
一条评论
Very well presented. Just one question - if one of these buttons (or rather the switch that it activates) has broken, how do you fix it? Where can you get a replacement part if that is what is needed?
Anthony Vallillo - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 1,572
