跳转到主内容
Thomas Ride On Train battery replacement
你所需要的
  1. Thomas Ride On Train battery replacement, Open the seat: 步骤 1 中的图像 1,1
    • Remove the seat by unscrewing the single screw located just by the backrest
    • Slide the seat backwards to unclip it
    • Unscrew the battery restraint
    • If you are replacing with an official replacement then it's a simple case of unclipping the old battery.
    • Alternative battery
    • If however you are swapping in an alternatively sourced battery you will need to cut off that clip.
    • The condition of the battery can most easily be told by charging it and seeing how much use you get out of it before it needs recharging again.
    • However if you have a multimeter then you can also look at the voltage of the battery.
    • Details of checking the battery
  2. Thomas Ride On Train battery replacement, Replacing the new battery: 步骤 4 中的图像 1,1
    • If you are using a official replacement battery this again should be a simple case of clipping the new one in place.
    • Finish up by replacing the restraining clip making sure to avoid trapping any wires. Replace the seat up by sliding it firmly forwards then screwing down
    • Crimp or solder on suitable connectors for the new battery ensuring that the red and black wires are connected to the same connectors on the battery.
    • It is a good idea to ensure that the battery can disconnected for future diagnosis, external charging or replacement
结论
另外一个人完成了本指南。
6条评论
Hi,
I need a new battery 6v for Thomas ride on train.
Can you pls recommend a brand? Or can I use 12v instead ? Thanks
kowalska.sa - 回复
Can I use 2 6v battery's to make this train go faster??
Reggie - 回复
If you use a 12v or two 6v attached in series it could damage the sound board.
Two 6v in parallel would give you a longer run the between charges.
Andy from Workshopshed - 回复
The official battery is 6v 4Ah, check the dimensions against the battery compartment or old battery
http://www.hedstrom.co.uk/shop/spares/th...
When replacing battery on the train the negative wire came off a little silver rectangular piece hooked to it what is this part and do I need it or can I bypass it
Leonard Breyne - 回复
Hey Leonard, are you talking about “spade connectors" ? It's a good idea to have the battery so that it can be quickly disconnected, soldering the wires to the battery would be a bad idea
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 23
过去 30 天: 73
总计 14,411
