跳转到主内容
ThinkPad Yoga 12 SSD Replacement
你所需要的
  1. ThinkPad Yoga 12 SSD Replacement, Screws: 步骤 1 中的图像 1,3 ThinkPad Yoga 12 SSD Replacement, Screws: 步骤 1 中的图像 2,3 ThinkPad Yoga 12 SSD Replacement, Screws: 步骤 1 中的图像 3,3
    • Remove the ten Phillips screws using a Philips 00 screwdriver
  2. ThinkPad Yoga 12 SSD Replacement, Prying: 步骤 2 中的图像 1,2 ThinkPad Yoga 12 SSD Replacement, Prying: 步骤 2 中的图像 2,2
    • Pry up the case carefully using a spudger.
    • Make sure to not push the spudger in too far, as this could result in internal damage
  3. ThinkPad Yoga 12 SSD Replacement, Lift off cover: 步骤 3 中的图像 1,1
    • Lift off the cover, and you're done!
  4. ThinkPad Yoga 12 SSD Replacement, Remove SSD from the laptop: 步骤 4 中的图像 1,2 ThinkPad Yoga 12 SSD Replacement, Remove SSD from the laptop: 步骤 4 中的图像 2,2
    • Carefully remove two Phillips screws with a Phillips 0 screwdriver
    • Static sensitive components!
  5. ThinkPad Yoga 12 SSD Replacement: 步骤 5 中的图像 1,2 ThinkPad Yoga 12 SSD Replacement: 步骤 5 中的图像 2,2
    • Gently grab the plastic tab. Lift and pull the SSD assembly out of the computer
  6. ThinkPad Yoga 12 SSD Replacement, Remove enclosure: 步骤 6 中的图像 1,2 ThinkPad Yoga 12 SSD Replacement, Remove enclosure: 步骤 6 中的图像 2,2
    • Remove the 4 identical Phillips screws with a Phillips 00 screw driver (they are on both sides).
  7. ThinkPad Yoga 12 SSD Replacement, Done!: 步骤 7 中的图像 1,2 ThinkPad Yoga 12 SSD Replacement, Done!: 步骤 7 中的图像 2,2
    • Carefully remove the SSD enclosure.
    • Note: The SSD enclosure is made of thin metal. It can be easily deformed. Be careful when removing from the SSD.
结论
6等其他人完成本指南。
[deleted]
于03/18/18注册
1,324 声望
创作了3篇指南
1指南评论
Almost perfect instructions. I do recommend removing the active pen first. Also it's a good idea to remind people that the active pen holder is screwed to the case cover from the inside and will come out as part of the cover.
Dani Deitch - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 21
总计 5,365
