跳转到主内容
ThinkPad Yoga 12 Battery Replacement
你所需要的
  1. ThinkPad Yoga 12 Battery Replacement, Screws: 步骤 1 中的图像 1,3 ThinkPad Yoga 12 Battery Replacement, Screws: 步骤 1 中的图像 2,3 ThinkPad Yoga 12 Battery Replacement, Screws: 步骤 1 中的图像 3,3
    • Remove the ten Phillips screws using a Philips 00 screwdriver
  2. ThinkPad Yoga 12 Battery Replacement, Prying: 步骤 2 中的图像 1,2 ThinkPad Yoga 12 Battery Replacement, Prying: 步骤 2 中的图像 2,2
    • Pry up the case carefully using a spudger.
    • Make sure to not push the spudger in too far, as this could result in internal damage
  3. ThinkPad Yoga 12 Battery Replacement, Lift off cover: 步骤 3 中的图像 1,1
    • Lift off the cover, and you're done!
  4. ThinkPad Yoga 12 Battery Replacement, Removing the screw: 步骤 4 中的图像 1,2 ThinkPad Yoga 12 Battery Replacement, Removing the screw: 步骤 4 中的图像 2,2
    • Remove the one and only Phillips screw with a Phillips 0 screwdriver.
  5. ThinkPad Yoga 12 Battery Replacement, Lift: 步骤 5 中的图像 1,2 ThinkPad Yoga 12 Battery Replacement, Lift: 步骤 5 中的图像 2,2
    • Carefully lift the battery. There is a small bit of adhesive underneath the green.
    • Make sure to not bend the battery! This can result in a violent explosion with flames and shrapnel!
  6. ThinkPad Yoga 12 Battery Replacement, Connecter: 步骤 6 中的图像 1,3 ThinkPad Yoga 12 Battery Replacement, Connecter: 步骤 6 中的图像 2,3 ThinkPad Yoga 12 Battery Replacement, Connecter: 步骤 6 中的图像 3,3
    • Carefully pull the connector out from underneath the logic board to remove the battery.
结论
9等其他人完成本指南。
[deleted]
于03/18/18注册
1,324 声望
创作了3篇指南
一条评论
These directions (and those for replacing the SSD) were very helpful. Everything worked well for about a week after which time the battery started having charging problems (again). The computer will start to charge, get to ~25% at which point the machine reports that it’s charging, but doesn’t get beyond ~25%. “Troubleshooting” in Win 10 doesn’t reveal any troubles to shoot. I am now trying to figure out whether the problem is with the new (supposedly Lenovo-brand) battery or perhaps the power cord. Any suggestions?
ellamama - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 11
过去 30 天: 16
总计 6,815
