跳转到主内容
ThinkPad T420 Keyboard Replacement
你所需要的
    • 1.For access, remove these FRUs in order: Battery pack FRU. Memory slot cover FRU.
    • 2.Push down the keyboard a little and slide it toward the arrow 2 to detach the front edge of the keyboard from the frame.
    • 3.Lift the keyboard a little in the direction shown by arrow, and then detach the connector
  1. ThinkPad T420 Keyboard Replacement, Keyboard installation:: 步骤 2 中的图像 1,1
    • 1.Attach the keyboard connector.
    • 2.Attach the keyboard so that the keyboard edges are under the frame as shown in this figure.
    • 3.To make sure that the front edge of the keyboard is housed firmly, gently press the keys with your palms and slightly slide the keyboard toward you until it snaps into position.
    • 4.Make sure that the front edge of the keyboard is attached firmly.
    • 5.Secure the keyboard by tightening the screws from the bottom side of the computer.
结论
另外一个人完成了本指南。
Laptop
于05/29/18注册
1,021 声望
创作了6篇指南
1指南评论
I do not belive the first step has a picture. That would be very helpful. Thanks anyways.
Alexander Wiand - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 50
总计 3,118
