跳转到主内容
ThinkPad Edge E31 Underside Disassembly
你所需要的
  1. ThinkPad Edge E31 Underside Disassembly, Battery: 步骤 1 中的图像 1,1
    • There are two two locks for the battery, one on the left and one on the right.
    • Slide the left lock to the left.
  2. ThinkPad Edge E31 Underside Disassembly: 步骤 2 中的图像 1,1
    • Slide and hold the right battery lock to the right.
    • While holding the right battery lock, slide the battery up to remove it from the laptop.
  3. ThinkPad Edge E31 Underside Disassembly, ThinkPad Edge E31 Underside Disassembly: 步骤 3 中的图像 1,1
    • The battery should be removed before accessing any internal components, and you should ground yourself before handling internal components.
    • Unscrew the 5 screws holding the back on. These screws will unscrew from the laptop, but will remain secured to the back plate even when fully loosened. Once unscrewed, the plate can be removed.
结论
Riley
于03/19/17注册
601 声望
创作了6篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 10
总计 323
