简介
Use this guide to replace a broken LCD in your ThinkPad 13 Chromebook, or upgrade the HD display to a FHD display on an entry-level model.
你所需要的
Use a Size 0 Philips screwdriver to loosen the nine screws on the bottom of the case. They will not come out entirely, but you will feel when they are loose enough.
You will need to remove the rubber pads from the bottom three screws using a pair of tweezers.
Use a spudger or other plastic tool to push the battery connector in the direction of the arrow, removing it from its socket.
Use the plastic opening tool to pull the panel forward and release it from the display assembly.
You may need a little help from your fingers for the thicker bottom bezel.
2等其他人完成本指南。
