跳转到主内容
Thermal paste replacement on the motherboard and processor
你所需要的
  1. Thermal paste replacement on the motherboard and processor, Open the computer housing: 步骤 1 中的图像 1,3 Thermal paste replacement on the motherboard and processor, Open the computer housing: 步骤 1 中的图像 2,3 Thermal paste replacement on the motherboard and processor, Open the computer housing: 步骤 1 中的图像 3,3
    • First step, locate the screws to disassemble the side of the housing.
    • They are often in the back (circled in red in our photo).
    • In some cases, it is a handle that must be operated.
    • As a rule, it is necessary to slide the cover sideways or lift it up.
  2. Thermal paste replacement on the motherboard and processor, Locate and disassemble the fan / heatsink from the CPU: 步骤 2 中的图像 1,3 Thermal paste replacement on the motherboard and processor, Locate and disassemble the fan / heatsink from the CPU: 步骤 2 中的图像 2,3 Thermal paste replacement on the motherboard and processor, Locate and disassemble the fan / heatsink from the CPU: 步骤 2 中的图像 3,3
    • The cooler consists of a heatsink and a fan located above the processor. The heatsink consists of an aluminum or copper part, which transfers heat from the processor and allows it to be evacuated by the fan.
    • Once located, disconnect the fan (indicated by the orange arrow). Then unscrew each of the mounting screws in turn while maintaining a slight pressure on the metal part of the heat sink.
    • Extract the heatsink by pulling it without over-straining the board. Most of the time, the fixing screws remain on the heatsink. Just like the fan, we will not separate it from the block.
    • If you realize that the cooler resists, do not use force. You would risk extracting the processor from its housing at the same time. This can happen on older computers, up to socket 423.
  3. Thermal paste replacement on the motherboard and processor, Cleaning off the old thermal paste: 步骤 3 中的图像 1,3 Thermal paste replacement on the motherboard and processor, Cleaning off the old thermal paste: 步骤 3 中的图像 2,3 Thermal paste replacement on the motherboard and processor, Cleaning off the old thermal paste: 步骤 3 中的图像 3,3
    • To put back new thermal paste, it is important to clean the remains of the old one
    • For this, alcohol of the ethanol or isopropyl type can be used to remove the old paste. The use of another type of alcohol leaves residues on drying. A plastic cloth or squeegee can be useful for removing residue.
    • Make sure you have cleaned the heat sink side AND the top of the processor.
  4. Thermal paste replacement on the motherboard and processor, Installation of the new thermal paste: 步骤 4 中的图像 1,2 Thermal paste replacement on the motherboard and processor, Installation of the new thermal paste: 步骤 4 中的图像 2,2
    • Once the two surfaces are clean, the new paste is applied on the processor side.
    • One drop is sufficient, the important thing is that it covers the entire zone in contact with the heat sink.
    • To be sure that it spreads well, it can be spread out using a plastic spatula. A thin layer of paste is required so that it does not overflow once the ventilator has been repositioned.
  5. Thermal paste replacement on the motherboard and processor, Reassembling the computer: 步骤 5 中的图像 1,1
    • We start by reassembling the heat sink, by screwing each piece (don’t over-tighten it all at once!)
    • Don't tighten the screws too much, when the screw locks, it's good to go
    • Reconnect the fan (connector circled in orange)
    • reclose the case
  6. Thermal paste replacement on the motherboard and processor, Check that the processor is cooled: 步骤 6 中的图像 1,1
    • The temperature of a processor at rest depends on each processor. To know its exact specifications and to know if you are in the standard, you just have to consult its technical sheet on the site of Intel or on that of AMD.
    • To know it, it is often marked in the BIOS or via the commands "sensors" or "lm_sensors" if you are on linux :)
    • If the temperature seems too high, the heatsink may have been incorrectly replaced, the fan may not have been correctly reconnected or there may not be enough thermal paste.
    • It is also possible that your environment is too hot, that you have not cleaned your fans or that dust is present in the housing. The more dust there is, the more the PC heats up, and the more dust it attracts, etc.
    • If none of these solutions overcome your problems, consider water cooling, processor undervolting, etc.
结论
And that's it, time to give your computer a new start :)
7等其他人完成本指南。
由衷感谢以下译者:
fr en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Diams
于07/06/23注册
288 声望
撰写一个指南
2指南评论
Merci pour ce tuto
Olivier Beya - 回复
Waouh Woah, je l'ai connu cet ordinateur, j'en ai démonté beaucoup de ces types serveur de super qualité de chez IBM, c'était une petite merveille pour l'époque
alain frenois - 回复
添加评论
浏览统计数据:
过去 24 小时: 17
过去 7 天: 138
过去 30 天: 551
总计 11,491
