跳转到主内容
Logitech G910 Lights Replacement
你所需要的
  1. Logitech G910 Lights Replacement, Lights: 步骤 1 中的图像 1,1
    • Unplug the keyboard from the computer.
  2. Logitech G910 Lights Replacement: 步骤 2 中的图像 1,1
    • Flip the keyboard and unscrew the 15 back screws. The screws in the palm rest must be unscrewed and the palm rest removed to access the 6 screws at the bottom of the keyboard. (There are 2 lengths of screws the shorter ones are for the palm rest) There are also 2 screws under the nonslip pads of the palm rest.
  3. Logitech G910 Lights Replacement: 步骤 3 中的图像 1,1
    • Release the front part using a spudger or flat screwdriver to gently pry. Lift off carefully.
  4. Logitech G910 Lights Replacement, Lift the film: 步骤 4 中的图像 1,2 Logitech G910 Lights Replacement, Lift the film: 步骤 4 中的图像 2,2
    • Gently lift up the plastic film in the top right corner.
结论
5等其他人完成本指南。
3条评论
So what do I do after I take apart my keyboard?
CuddlyZebesian - 回复
this guide is currently missing some steps. If you have figured it out, pls edit this guide.
tayola -
Desolder and replace LEDs the size of a grain of sand xD
This is definitely not a job I'd mark as "easy".
squallloire -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 29
过去 30 天: 81
总计 6,025
