简介
This tutorial will help you replace the battery of your Pave Parisien
Pull the speaker out a bit to access the connectors
With light gentle movements, pull and disconnect the two cables from the connections
Pull the speaker completely out of the recessed compartment
Gently pull the board behind the speaker out and place on a flat surface
Disconnect the battery connector from the board
Be careful to pull gently using a small screwdriver to pry up the clip, then apply gentle pressure
Push the battery from the rear towards the opening where the wires are
The battery is out and now it can be changed
The texture of this surface is different from the other three faces. Orient yourself to how it fits correctly.
First connect the positive and negative wires, then slide the speaker in the enclosure in the right orientation
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
