跳转到主内容
The Internal Components of an Atari Lynx
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. The Internal Components of an Atari Lynx, Atari Lynx: 步骤 1 中的图像 1,1
    • Before disassembling your Atari Lynx, be sure the device is powered off.
    • Remove any game in the console by opening the right latch and sliding the game to the right.
  2. The Internal Components of an Atari Lynx: 步骤 2 中的图像 1,1
    • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Pinch the rear panel with your fingers and lift away from the Atari.
  3. The Internal Components of an Atari Lynx: 步骤 3 中的图像 1,1
    • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear any wires attached to battery panel.
  4. The Internal Components of an Atari Lynx: 步骤 4 中的图像 1,1
    • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear the speaker wire while removing the control panel.
结论
John Lopez
于01/27/14注册
443 声望
创作了4篇指南
团队
Cal Poly, Team 1-42, Maness Winter 2014 Cal Poly, Team 1-42, Maness Winter 2014 的会员
CPSU-MANESS-W14S1G42
5 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 101
